Go Back   race-dezert.com > the deZert people 3.0 community > Shop > Shop - Miscellaneous
Notices
Reply
Thread Tools Display Modes Translate
Old April 11th, 2001, 20:11   #1
Wayne_Nosala
Wayne_Nosala's Avatar
Posts: 616   (View Stats)
Wayne_Nosala has much to be proud ofWayne_Nosala has much to be proud ofWayne_Nosala has much to be proud ofWayne_Nosala has much to be proud ofWayne_Nosala has much to be proud ofWayne_Nosala has much to be proud ofWayne_Nosala has much to be proud of
Not Ranked
Default Fluidyne oil cooler
Hi gang
I just purchased a Fluidyne oil cooler, with the fan
Im replacing an original "Rapid cool" oil cooler
(you veterans may remember these, this thing could
almost be considered an antique!)
Anyway im told NOT to mount the fluidyne rigid to my buggy chassis
It my twist & break the cooler
Im familiar with a rubber mount the McMaster Carr sells,
basically its a round rubber thing with a threaded studs protruding
from end to end, but i hear these can also fail if mounted in the "shear position"
Im open to suggetions as to whare to get a better rubber mount
for this cooler
Thanks in advance
Wayne
Wayne_Nosala is offline   Reply With Quote
Old April 12th, 2001, 10:08   #2
El Chinero
Posts: 696   (View Stats)
El Chinero is a name known to allEl Chinero is a name known to allEl Chinero is a name known to allEl Chinero is a name known to all
Not Ranked
Default Re: Fluidyne oil cooler
The bonded stud types certainly can shear ... and often do.
Try this site for high(er) tech mounts
http://www.westernrubber.com/vibratio.htm
what you want is a multi-piece unit with a through-bolt that, in the case of grommet wear, would still retain the cooler ... "fail-safe", as it were.
I would also check out motorcycle equipment mounts ... like on XRs ... they have, in the past, used necked grommets with an nternal steel spacer which can be torqued -- very important -- without crushing the grommet.
(I am not remotely near my XR at this itme.)
TT de GA
Tony T
El Chismoso
El Chinero is offline   Reply With Quote
Old April 12th, 2001, 11:52   #3
Eric
Eric's Avatar
Posts: 65   (View Stats)
Eric is on a distinguished road
Send a message via AIM to Eric Send a message via Yahoo to Eric
Not Ranked
hmm, haven't heard that.. I run the Fluidyne single core on my 10 car and have bolted in directly behind mine and the co-passengers head vertically... it is rock solid and has never moved or stretched out the mounts at all plus it gets great air flow..
It has done around 4 races to date with no problem.. I do know that if you have the two-core Fluidyne that it should be mounted horizontally or angled on the buggy and not vertical..
Eric
#1012
Z-YA Racing
Eric is offline   Reply With Quote
Old April 12th, 2001, 17:32   #4
L&SMotorsports
Posts: 110   (View Stats)
L&SMotorsports will become famous soon enough
Not Ranked
Hey Wayne, how are you? I put that same oil cooler on the race car a few races ago, it's a real nice unit. I used the rubber stud mount that you are talking about, then I ran a bolt thought another hole and jam-nutted it loose, so if the rubber mount breaks, the cooler won't bounce around. The rubber mounts were a little hard to tighten down, so I took of the locking nuts it came with and used regular nuts, then monkey snotted them. Have fun in Ridgecrest this weekend, and let me know what you see out there.
Tim
L&SMotorsports is offline   Reply With Quote
Old April 12th, 2001, 17:42   #5
Posts: 2,890   (View Stats)
rdc has a spectacular aura about
Not Ranked
Not sure but the upper radiator mnts. from a 97 ranger might work also. They are rubber with crush sleves. They held up on my truck even when I pushed the rad. into the fan. If you call Ford here are the specs: 4.0l , 2wd, 4 row rad. w/AC, manual trans. Rubber will save it if the area of the chassis you mount the cooler to gets tweaked a bit. Good luck!
Tony
rdc is offline   Reply With Quote
Old April 13th, 2001, 00:06   #6
Wayne_Nosala
Not Ranked
Thanks Tony & Eric & Tony for the reply
I got some grommets from a local electronics store, but they
looked too wimpy
So I was poking around the auto parts today,
I found a grommet called a "wiper moter mount".
Its a pretty stiff grommet with a steel sleave though it.
I had to increse the hole size in the cooler flange to 5/8"
They look like they will do the trick, They look
like they will have just enough squish to them to compensate
for any chassis flex,& the steel sleave allows me to snug
the assembly down tight.
Thanks again for the help.
Hey Tim!
We will be in Ridgecrest Saturday & Sunday
(depending on how Brads been feeling, he's been sick all week)
How is your car comming?
If there is anything i can help with from down here, let me know
Wayne
Old April 13th, 2001, 00:29   #7
Wayne_Nosala
Not Ranked
attached picture of grommet
Click image for larger version
Old April 13th, 2001, 20:47   #8
DMSRACE
Posts: 650   (View Stats)
DMSRACE is on a distinguished road
Send a message via AIM to DMSRACE
Not Ranked
kartek has the rubber isolaters in stock 909-628-0833
DMSRACE is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
